Введение
The screws on the brakes are tight, but it's best to use hand tools so the screws don't get stripped.
Выберете то, что вам нужно
Remove the two, 23 mm Hex #5 screws holding the brake to the bike.
Slide the brake mechanism off and turn it upside down to reveal the screw holding the brake wire.
Remove the one, 14 mm Hex #4 screw pushing down the brake wire to the brake mechanism on the bottom.
Remove the side screw holding the brake wire and mechanism together with your hands.
Slide the brake mechanism off from the brake wire.
Еще один человек закончил это руководство.
