How To Fix A Hole In Khaki Pants
Выберете то, что вам нужно
  1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: шаг 1, изображение 1 из 1
    • Examine the damaged area.
    • Make sure to clean all the debris from the tear.
  2. How To Fix A Hole In Khaki Pants: шаг 2, изображение 1 из 1
    • Flip your pants inside out.
  3. How To Fix A Hole In Khaki Pants: шаг 3, изображение 1 из 1
    • Pinch hole together.
    • Make sure there is no gaps showing.
  4. How To Fix A Hole In Khaki Pants: шаг 4, изображение 1 из 1
    • Pin needle and thread through pants.
    • Use more thread than needed so you will have enough.
    • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
  5. How To Fix A Hole In Khaki Pants: шаг 5, изображение 1 из 2 How To Fix A Hole In Khaki Pants: шаг 5, изображение 2 из 2
    • Pull needle and thread through pants until there is only 2 inches of thread left.
    • Tie a knot at the end of the remaining 2 inches.
    • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
  6. How To Fix A Hole In Khaki Pants: шаг 6, изображение 1 из 2 How To Fix A Hole In Khaki Pants: шаг 6, изображение 2 из 2
    • Take the needle and pin it through right next to the previous spot.
    • Pull all the way through until thread is tight.
    • Repeat this process until you reach the end of the hole.
  7. How To Fix A Hole In Khaki Pants: шаг 7, изображение 1 из 1
    • Wrap the thread three times around the needle.
    • Pull the needle until the thread is tight.
    • This will tie a knot at the end.
  8. How To Fix A Hole In Khaki Pants: шаг 8, изображение 1 из 1
    • Take the scissors and cut the excess string remaining.
  9. How To Fix A Hole In Khaki Pants: шаг 9, изображение 1 из 1
    • Now put your khaki pants on because they are now wearable again and practically new!
Заключение
Now your old ripped pants look practically new and you can begin wearing them again.
6 участников успешно повторили данное руководство.
Calvin Roth
Участник с: 09/27/15
291 Репутация
1 руководство автора
Команда
Cal Poly, Team 17-1, Green Fall 2015 Участник Cal Poly, Team 17-1, Green Fall 2015
CPSU-GREEN-F15S17G1
4 членов
Автор 5 руководств
5 Комментариев
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - Ответить
Iam shafik i can't do it's and 100% maching
What about if you’re in school and your pants rip?
EMMA MILLER - Ответить
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 33
За последние 30 дней: 142
За всё время: 51,016
