Введение
Use this guide to stop a leak in a common cartridge faucet.
Инструменты
Запчасти
Детали не указаны.
Shut off the hot and cold water valves underneath the sink by twisting them clockwise until they are tight.
To test that the water has been completely shut off, try turning on the faucet like you would normally. If no water comes out, you're in luck!
Pull up on the the pop-up drain stopper to seal the sink drain.
Place a towel in the sink to catch any excess water or faucet hardware.
Use your fingers or a prying tool to remove the plug button from the top of the faucet handle.
2 участников успешно повторили данное руководство.
