How To Fix A Loose Bicycle Pedal And Check For Damage
Выберете то, что вам нужно
  1. How To Fix A Loose Bicycle Pedal And Check For Damage, How To Fix A Loose Bicycle Pedal And Check For Damage: шаг 1, изображение 1 из 1
    • Flip the entire bicycle upside down, balancing the weight on the seat and handle bars.
    • This will keep the bicycle stable while you work on it.
  2. How To Fix A Loose Bicycle Pedal And Check For Damage: шаг 2, изображение 1 из 3 How To Fix A Loose Bicycle Pedal And Check For Damage: шаг 2, изображение 2 из 3 How To Fix A Loose Bicycle Pedal And Check For Damage: шаг 2, изображение 3 из 3
    • You will need an Allen Wrench or a Smart Wrench for this repair.
    • If you are using an Allen Wrench, insert the head of the wrench into socket located on the pedal arm.
    • If you are using a Smart Wrench, place the jaws on the nut located between the pedal and pedal arm.
    • Loosen the pedals by turning the right pedal counterclockwise and the left pedal clockwise.
    • Remove the pedal from the socket.
  3. How To Fix A Loose Bicycle Pedal And Check For Damage: шаг 3, изображение 1 из 2 How To Fix A Loose Bicycle Pedal And Check For Damage: шаг 3, изображение 2 из 2
    • Check the socket and bolt for rust and worn threads.
    • If you notice damages like rust or worn threads, you will need to refer to a separate repair guide specific to the type of damage.
    • If you do not see any damage, continue to Step 4.
  4. How To Fix A Loose Bicycle Pedal And Check For Damage: шаг 4, изображение 1 из 3 How To Fix A Loose Bicycle Pedal And Check For Damage: шаг 4, изображение 2 из 3 How To Fix A Loose Bicycle Pedal And Check For Damage: шаг 4, изображение 3 из 3
    • Place the pedal back in the socket and tighten it until it is secure.
    • To tighten the pedals, turn the right pedal clockwise and the left pedal counterclockwise.
    • Once you feel resistance, turn the pedal about 1/8 of a rotation further to properly tighten it.
    • DO NOT use excessive force when you are tightening the pedal. This can lead to difficulty removing the pedal in the future.
Заключение
If both pedals need tightening follow the steps again, remembering to turn the opposite directions for tightening and loosening.
9 участников успешно повторили данное руководство.
Thomas Paulsen
Участник с: 02/23/15
218 Репутация
1 руководство автора
Команда
Cal Poly, Team 12-1, Green Winter 2015 Участник Cal Poly, Team 12-1, Green Winter 2015
CPSU-GREEN-W15S12G1
6 членов
Автор 7 руководств
5 Комментариев
Yes, I agree, it's very nice way to fix pedals.
Praska - Ответить
Would you be able to tell me how to fix a locked up bike
Hughes Zass - Ответить
Wenn das Rad auf dem Kopf steht, ist das linke Pedal rechts und umgekehrt.
Klaus Giezek - Ответить
My crank arm constantly comes loose, although I tightened it. I go to the bike repair store near my house, and they say that the bearing of the bottom bracket is worn. To fix this, I need to replace it with a new one, grease the new component, and tighten the bicycle crank.
Bruno John - Ответить
Some reasons that crank arm keeps coming loose can happen, such as: the bolts are loose and damaged; incorrect installation; the bearing is damaged; the spindle is wiped out; An unfitting bottom bracket,...
Добавить комментарий
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 52
За последние 30 дней: 219
За всё время: 65,868
