How To Fix Vertical Lines On An iPhone Screen After Replacement
Выберете то, что вам нужно
  1. How To Fix Vertical Lines On An iPhone Screen After Replacement, Electro-Static Discharge (ESD): шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Anti-Static Mat
    $24.99
    Купить
    • ESD is a common culprit behind display malfunction.
    • Ground yourself and your device to discharge any built up static charge before repairing your phone. The best way to do this is to use an anti-static mat and wear an anti-static wrist strap.
  2. How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: шаг 2, изображение 1 из 3 How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: шаг 2, изображение 2 из 3 How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: шаг 2, изображение 3 из 3
    • Check the display connections on the cables and the logic board. Dirt, dust or debris can cause a faulty connection and should be cleaned with a soft brush and high concentration isopropyl alcohol (at least 90%). Inspect the connectors and clean as necessary.
    • Isopropyl alcohol is a mild skin and eye irritant. Use gloves and eye protection while working with isopropyl alcohol.
  3. How To Fix Vertical Lines On An iPhone Screen After Replacement, Damaged IC Connector: шаг 3, изображение 1 из 1
    • The display has an IC that could be damaged. Check particularly on the upper left and right corners. Any signs of damage indicate the part is defective and needs to be replaced with a new one.
Заключение
Screens are fragilé (it must be Italian)
128 участников успешно повторили данное руководство.
Matt Zieminski
Участник с: 02/23/15
33 465 Репутация
Автор 13 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
9 Комментариев
i had a same problem so can someone sent me the video so that video will help me a lot thanks
Suman Biswa - Ответить
i have 4he same problem, mines worse, soon as i turn it on verticle lines its bad you cannot see any thing only lines.. brand new screen with lcd, its not working!!! any solutions? im thinking of o new logic board…
jubonygill - Ответить
I had the same problem when removing and installing an iPhone 6 plus battery. After connecting all four flex cables to the mother board the phone either would not boot up or there were vertical lines on the display. Basics, basics, basics……unplug battery connector. Unplug all four flex cable connectors. Re-attach all four flex cable connectors, then connect battery flex cable. After installing both metal shields and closing the phone it booted up properly and worked just like new. Viola!
bassinbill42 - Ответить
Did you have any problems after doing that to your phone? Or does it still have the lines?
sscorpion34 -
How to fix the vertical lines camera on iPhone 6
Renz Mendi - Ответить
My iPod 4th gen (16 gb) started doing this with the screen (minus the lines).
It’s just fuzzy and it will load and such and works fine otherwise.
If I wait about 30 mins to an hour, it will clear up and be a normal screen again.
I just don’t know how to fix it if it gets worse. Right now I can still kind of see what’s on the screen when this happens.
Lehsa Benden - Ответить
My iPhone6s has been turning on the apple logo then going to a blank screen with a single line threw it for the past week or so and continues to not turn on any suggestions on how to clear these glitches from the software?
Cody short - Ответить
bassinbill42 you are a lifesaver!!! I didn’t know what to do next after reconnecting the cables 4 times!! Thanks!!
who922 - Ответить
Mine is not that bad.. whenever I turned my screen on and off the lines are not there but slowly show after few seconds. What should I do?
azenile_14 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 41
За последние 7 дней: 320
За последние 30 дней: 1,343
За всё время: 454,824
