Введение
A damaged or broken hook can make an otherwise perfectly fine bra suddenly unwearable. This guide shows how simple and quick this all too common issue can be fixed.
Выберете то, что вам нужно
Use a seam ripper to rip off the seams on either side of the broken hook and also the edge seam.
Remove the broken hook from the strap.
Pull or cut off the threads that are still attached to the strap.
Place the tip of the pin next to the new hook.
Push the pin until it goes through the strap and reach for back of the pin.
Point the tip of the pin next to the other side of the hook.
Push pin again to make it go through to the front of the strap.
Thread needle with thread the same color as the bra.
Pull the thread through to an appropriate length.
Cut the thread.
Feel around for one of the two holes at the bottom of the new hook.
Stick the threaded needle through the hole of the hook.
Use a backstitch to sew the hook into place.
Repeat this for the other hole in the same hook.
Make a large loop with the thread when finished sewing the hook into place.
Place your finger on the point where you would like the knot to be and pull on the thread.
Tie a knot at the end when you finish closing the seam.
Hold finger down on the thread to make sure the knot is as close to the bra as possible.
Tada! You saved your bra from an early grave in the dump!
11 участников успешно повторили данное руководство.
9 Комментариев
What size hook do I need?
Thank you . you took it from being overwhelming to …. Its fixed. Yippeee thank
Your instructions were super clear — It works!!! Thank you!
beautiful instructions. thank you for clear pictures too. i knew it was possible but it was nice to see a step by step.
