Введение
LED daytime running lights are a great add-on to any vehicle to increase light output for style and safety. Some LED daytime lamps are vehicle specific, but this set of Philips Style LED DRL is universal fit for more cars and SUVs.
Инструменты
Запчасти
Insert the wire into the bracket.
Mount the bracket. Since this is universal fit, you can mount it anywhere you'd like.
After mounting the bracket, you can lock the LED daytime running light on the bracket.
Connect the wires and route the wires up and near the fuse box.
Use zip ties to tie the wire along the bumper.
Find the ACC in your fuse box and tap the red wire there.
You can find the ACC location using an electronic meter by clamping the black wire to the battery negative or ground.
When you find ACC, tap the red wires to the blade of the fuse and insert it back.
Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights.
As you can see, installation isn't complicated and if you follow the directions accordingly, you'll be on your way to new LED daytime running lights in no time.
21 участников успешно повторили данное руководство.
Комментариев: 11
Useful information shared. Thanks for giving us nice info. Fantastic walk through. I appreciate this post and here is my link
Useful info. Thanks
great information and pictures, just one thing, what size of fuse should I use for connection in fuse box.
UK road/MOT law states you must 60% dim or better still, make DRL’s turn off when headlights are turned on … stop advertising fake information Phillips and start stating some facts for a change
