How To Remove Scratches From A Hardwood Floor
Выберете то, что вам нужно
  1. How To Remove Scratches From A Hardwood Floor, How To Remove Scratches From A Hardwood Floor: шаг 1, изображение 1 из 1
    • Identify the scratch you would like to repair.
  2. How To Remove Scratches From A Hardwood Floor: шаг 2, изображение 1 из 1
    • Using a hardwood cleaner and a clean cloth, wipe the area down to remove any dirt or debris.
  3. How To Remove Scratches From A Hardwood Floor: шаг 3, изображение 1 из 1
    • Using painter's tape, isolate the area of the scratch.
    • Try to keep the tape as close to the scratch as possible.
  4. How To Remove Scratches From A Hardwood Floor: шаг 4, изображение 1 из 1
    • Apply wood filler into the scratch using a putty knife.
    • Try to make sure every part of the scratch has been filled. Too much is better than too little here.
  5. How To Remove Scratches From A Hardwood Floor: шаг 5, изображение 1 из 2 How To Remove Scratches From A Hardwood Floor: шаг 5, изображение 2 из 2
    • After drying for 10-15 minutes, sand the area down until the wood filler is level with the rest of the floor.
  6. How To Remove Scratches From A Hardwood Floor: шаг 6, изображение 1 из 1
    • Find a stain pen that will match as close as possible to the finish of your floor. Apply this stain to the wood filler and let it dry.
  7. How To Remove Scratches From A Hardwood Floor: шаг 7, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Microfiber Cleaning Cloths
    $3.99
    Купить
    • After drying completely, apply some wipe on polyurethane to a microfiber cloth or towel.
    • Buff the area with the cloth.
    • This will ensure the sanded area will regain it's shine and blend in with the rest of the floor.
  8. How To Remove Scratches From A Hardwood Floor: шаг 8, изображение 1 из 1
    • After applying the wipe on polyurethane, your scratch should now be blended in with the rest of the floor.
Заключение
The scratch will hardly be noticeable after this repair. Depending on the depth of the scratch, it is possible this fix will not make the floor look good as new. For very deep scratches the only remedy may be to replace the floor board.
Ryan Nicasio
Участник с: 01/21/21
157 Репутация
1 руководство автора
Команда
York University, Team S2-G16, O'Regan Winter 2021 Участник York University, Team S2-G16, O'Regan Winter 2021
YORK-O'REGAN-W21S2G16
1 член
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 52
За всё время: 514
