Введение
In this guide we will be learning how to remove a headliner from a 2002 Dodge Dakota. We will be removing the visor, the visor clips, rear ceiling clips, the rear light, the center light, and the side panel. Please read and follow all instructions, and no parts will be damaged, and you will be able to successfully remove the headliner. Good luck and have fun!
Выберете то, что вам нужно
Remove the two Phillips #0 screws on the two visor mounts on either side of the cab.
Insert a flathead screwdriver 1/8th of an inch into the visor clip and gently pry up on the clip.
Repeat the process from all 4 corners of the clip, until the top portion of the clip is half an inch from the headliner.
Pull out the clip.
Repeat on the other side of the cab.
Insert a flathead screwdriver into the top of the crevice on the rear ceiling clips. Gently pry back and forth until it springs open, revealing the screw inside.
Use the 7/32" Allen wrench to remove the screw and pull on the clip to take it off.
Repeat on other side of the cab.
Use a flathead screwdriver to gently pry off the rear light fixture.
Disconnect the wiring by squeezing both nobs on the wiring end and pulling away from the light. The wiring will pop out.
Use a screwdriver or two to get underneath the clips and pry them up as much as possible.
Grab the tab firmly and pull it out in one continuous motion, moving it side to side or rotating it as needed.
Repeat process on the second tab.
Choose a side that you will focus on. Line up your flathead with the side of the light that you chose and gently pry it up with increasing pressure until one of the two main clips disengages.
After the console pops out, disconnect the wiring for the light cables.
Remove the seatbelt cover. This is held by two mini clips on either side of the cap. They are flexible so you could just pry the cap off, but if wanted, use your flathead screwdriver to poke the clips out of place and remove the capping.
This panel has 3 clips very similar to the rear tabs highlighted in step 5, as well as one big screw.
Use either a big Allen wrench or a pipe wrench to remove the big screw under the capping.
Gently pry each corner of the panel away from the wall to disengage each of the 3 clips, and the panel will pop out.
Slowly remove the headliner from the vehicle.
We're done! Congratulations on successfully removing the headliner without causing damage to any parts. Thank you!
Еще один человек закончил это руководство.
