Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The feathers in a down jacket need to be held in place or else they’ll all slide to the bottom of the jacket, leaving your upper torso and shoulders without insulation. The easiest method to prevent this is simply sewing the jacket’s outer and inner fabrics together with seams to keep the feathers from shifting about. While this type of construction solves the problem of feather migration, the seams and corresponding holes in the fabric allow moisture and cold air to penetrate the jacket, decreasing the down’s insulating efficiency. Many Patagonia jackets incorporate internal baffles to keep the down from shifting. The baffle acts like a shelf inside your jacket to hold the down insulation while eliminating the need for seams that pierce both the internal and external fabric. While this is a more complicated construction method, the performance of the finished jacket is greatly improved. This guide shows you how to repair a non-lined portion of your jacket. If you’re not sure whether or not your jacket is lined, or you have a lined jacket, complete our How to Access the Insides of a Patagonia Down Jacket Guide before you follow the steps in this guide.
For replacement parts or further assistance, contact Patagonia Customer Service.
Видео обзор
Down jacket baffle repair overview.
  1. Locate the hole in your down jacket. In order to prevent all the feathers from escaping through the hole, you'll have to replace the entire baffle.
    • Locate the hole in your down jacket. In order to prevent all the feathers from escaping through the hole, you'll have to replace the entire baffle.
  2. Cut a small oval of Tenacious Tape large enough cover the hole. Cut a small oval of Tenacious Tape large enough cover the hole.
    • Cut a small oval of Tenacious Tape large enough cover the hole.
  3. Peel the backing off the tape, and apply it to the hole. Peel the backing off the tape, and apply it to the hole. Peel the backing off the tape, and apply it to the hole.
    • Peel the backing off the tape, and apply it to the hole.
  4. Use a seam ripper to rip the seam at the end of baffle that needs a repair. In this case, the nearest seam is along the sleeve. Rip a large segment of the seam, so that the jacket is comfortable to work with. Rip a large segment of the seam, so that the jacket is comfortable to work with.
    • Use a seam ripper to rip the seam at the end of baffle that needs a repair. In this case, the nearest seam is along the sleeve.
    • Rip a large segment of the seam, so that the jacket is comfortable to work with.
  5. Turn the jacket inside out. Measure the width of the baffle you're working on. In this case, each baffle looks like it is two inches wide. We are replacing two baffles, so we will need just over four inches of fabric to patch.
    • Turn the jacket inside out.
    • Measure the width of the baffle you're working on. In this case, each baffle looks like it is two inches wide.
    • We are replacing two baffles, so we will need just over four inches of fabric to patch.
    • Measure the length of the baffle (along the baffle seam). In our case, the baffle length is nine inches, and since our repair is in the sleeve, we will double this to eighteen inches for the length of our scrap.
  6. Get a scrap of matching fabric to patch the baffle. Make sure you have enough fabric to cover the area you measured in the previous step, with an inch or two extra in each direction. We are using a piece of fabric that is slightly lighter than our jacket, so you can easily identify which areas we are working on.
    • Get a scrap of matching fabric to patch the baffle. Make sure you have enough fabric to cover the area you measured in the previous step, with an inch or two extra in each direction.
    • We are using a piece of fabric that is slightly lighter than our jacket, so you can easily identify which areas we are working on.
    • Fold one of the long edges of the fabric over so that it is straight.
  7. Iron the fold into place. Iron the fold into place. Iron the fold into place.
    • Iron the fold into place.
  8. Align the folded edge of the scrap along the outermost seam on the baffle you want to replace. Be sure the rough, folded-over fabric is between the baffle with the hole and the new scrap of fabric. Align the folded edge of the baffle with the seam, and pin it into place.
    • Align the folded edge of the scrap along the outermost seam on the baffle you want to replace.
    • Be sure the rough, folded-over fabric is between the baffle with the hole and the new scrap of fabric.
    • Align the folded edge of the baffle with the seam, and pin it into place.
  9. Set the pinned piece into the sewing machine. Be sure to use the smallest needle you can find to patch this baffle. This will keep the new stitch from looking too prominent and help prevent the down from escaping through the new stitching holes. Sew directly over the old baffle seam. You will be sewing very close to the edge of the fold, just catching the fabric.
    • Set the pinned piece into the sewing machine.
    • Be sure to use the smallest needle you can find to patch this baffle. This will keep the new stitch from looking too prominent and help prevent the down from escaping through the new stitching holes.
    • Sew directly over the old baffle seam. You will be sewing very close to the edge of the fold, just catching the fabric.
    • If you’re working on a sleeve, make sure you only have one layer of the sleeve and that you’re not sewing the entire sleeve shut.
    • Go slowly, and guide the folded edge of the fabric directly over the old baffle seam. You may have to realign the folded edge of the fabric as you go—that's okay.
  10. While you're sewing, be sure to hold the bias tape (which covered the seam edge) out of the way so that it doesn't get caught in the seam. Continue to carefully sew the fold into place. The fabric is very slippery, so be careful and take your time. Judge the seam to your liking.
    • While you're sewing, be sure to hold the bias tape (which covered the seam edge) out of the way so that it doesn't get caught in the seam.
    • Continue to carefully sew the fold into place.
    • The fabric is very slippery, so be careful and take your time. Judge the seam to your liking.
    • When you come to the end of the seam, backstitch to keep your thread in place.
  11. We are working with three baffle seams in total. You've already sewn one at the outer edge. Skipping the baffle seam in the middle, pin the second fold into place on the seam at the other outer edge. Sew the second seam as you did the first. Sew the second seam as you did the first.
    • We are working with three baffle seams in total. You've already sewn one at the outer edge. Skipping the baffle seam in the middle, pin the second fold into place on the seam at the other outer edge.
    • Sew the second seam as you did the first.
  12. Continue sewing. When you are finished, your jacket should look like the second image.
    • Continue sewing.
    • When you are finished, your jacket should look like the second image.
  13. Turn the jacket right-side out again so you can see the original baffle stitching. Be sure to flip the bias tape out of the inside of the seam so it doesn't get caught as you continue to sew. Align your presser foot on top of the untouched, middle seam (between the two seams you've already sewed).
    • Turn the jacket right-side out again so you can see the original baffle stitching.
    • Be sure to flip the bias tape out of the inside of the seam so it doesn't get caught as you continue to sew.
    • Align your presser foot on top of the untouched, middle seam (between the two seams you've already sewed).
  14. Sew directly over the original middle baffle stitching between the two seams you just made. Be sure to hold the bias tape out of the way. Be sure to hold the bias tape out of the way.
    • Sew directly over the original middle baffle stitching between the two seams you just made.
    • Be sure to hold the bias tape out of the way.
  15. Trim off the excess fabric. Trim off the excess fabric.
    • Trim off the excess fabric.
  16. For our repair of the sleeve, we need to realign the sleeve seam that we ripped. Pull the bias tape out of the way. Sew the sleeve seam closed, backstitching at the beginning and end of the seam.
    • For our repair of the sleeve, we need to realign the sleeve seam that we ripped.
    • Pull the bias tape out of the way.
    • Sew the sleeve seam closed, backstitching at the beginning and end of the seam.
  17. Replace the bias tape over the completed sleeve seam. Adjust it so it sits correctly on both sides of the seam.
    • Replace the bias tape over the completed sleeve seam.
    • Adjust it so it sits correctly on both sides of the seam.
  18. Sew the bias tape back on. Make sure you sew as close to the inside edge of the bias tape as possible. Backstitch at both ends of the seam. Backstitch at both ends of the seam.
    • Sew the bias tape back on. Make sure you sew as close to the inside edge of the bias tape as possible.
    • Backstitch at both ends of the seam.
  19. Inspect your seams. Make sure that everything is in place, clip your threads, and be very proud of yourself. That was a tough repair. Inspect your seams. Make sure that everything is in place, clip your threads, and be very proud of yourself. That was a tough repair.
    • Inspect your seams. Make sure that everything is in place, clip your threads, and be very proud of yourself. That was a tough repair.
Финишная черта
13 участников успешно повторили данное руководство.
Brittany McCrigler
Участник с: 05.03.2012
85 717 Репутация
Автор 132 руководств
Комментариев: 11
This looks so complicated and I don't own a sewing machine.
soconnell - Ответить
I could never do this myself. Is there any talented seamster or seamstress out there who has done this before and would like to do my repair for a fee?
Can one buy matching fabric from patagonia?
danilowitz - Ответить
Yes, this seems overwhelming. Patagonia, please sell simple, iron-on supplies in your colors. This would be a GENIUS move. I just bought a used Down Sweater for a mere $30 and need to repair 2 holes. My plan is to stitch them tight with a needle & thread in a similar color (it's Viking Blue), but was hoping for a SIMPLE patch solution on here. None exists. Most of us don't have time for replacing baffles, and aren't looking for perfection. Matching colors would be awesome. As would a clear patch that will last through a lifetime of washes, and has Patagonia's seal of approval. I bet you could come out with a line of simple fix-it products. Even if iron-on solutions only last for say, 10 washes or something. Give busy, working moms like me who rely on your outerwear easier solutions so we can continue to buy used and keep up the green circle, so your products continue to see many years of life. :)
Rachel - Ответить
The other option is to send it in to Patagonia's repair center, it will be free as everything at Patagonia is covered by the Iron Clad Guarantee. They will fix it or replace for free, regardless of when it was bought, how bad of a rip it is, etc.
Mary - Ответить
please upload some vids to: how to repair big down jacket to fit off (from L size to M size)
thank you
mark santos - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 35
За последние 7 дней: 273
За последние 30 дней: 1,479
За всё время: 122,004
