How To Repair a Hole in a Crochet Blanket
Выберете то, что вам нужно
  1. How To Repair a Hole in a Crochet Blanket, How To Repair a Hole in a Crochet Blanket: шаг 1, изображение 1 из 1
    • Carefully unpick any torn or damaged stitches that have become separated from the main body of the blanket.
    • Take your time while separating the strands. Pulling too hard may cause additional damage to the blanket.
  2. How To Repair a Hole in a Crochet Blanket: шаг 2, изображение 1 из 2 How To Repair a Hole in a Crochet Blanket: шаг 2, изображение 2 из 2
    • Secure any loose or dangling stitches by threading the bottom loops with stitch markers and clasping them closed.
    • This will keep the stitches from accidentally unraveling and making the hole larger.
  3. How To Repair a Hole in a Crochet Blanket: шаг 3, изображение 1 из 1
    • After you’ve secured all of the loose stitches, it's time to fill in the hole. Join your new yarn to the first stitch on the bottom row.
    • If you can’t locate the exact yarn used in the blanket, try your best to match the color, material, and weight of the original yarn as closely as possible.
  4. How To Repair a Hole in a Crochet Blanket: шаг 4, изображение 1 из 3 How To Repair a Hole in a Crochet Blanket: шаг 4, изображение 2 из 3 How To Repair a Hole in a Crochet Blanket: шаг 4, изображение 3 из 3
    • Follow the original stitch pattern, starting at the bottom row and working from right to left.
    • This example uses a three double-crochet cluster, also known as a granny cluster.
    • When you're finished with a row, join with a slip knot and fasten off. Start the next row and repeat Steps 3 and 4.
  5. How To Repair a Hole in a Crochet Blanket: шаг 5, изображение 1 из 2 How To Repair a Hole in a Crochet Blanket: шаг 5, изображение 2 из 2
    • When you reach the last row, take out the stitch markers in the top row of stitches.
    • Insert your hook through the bottom loops of the stitch. Yarn over and pull through all of the loops on your hook.
    • This attaches the top row of existing stitches to your new stitches below.
    • Repeat for the rest of the row.
  6. How To Repair a Hole in a Crochet Blanket: шаг 6, изображение 1 из 1
    • Once you are finished, fasten off and weave in your ends.
Финишная черта
4 участников успешно повторили данное руководство.
Aisha Ali
Участник с: 04/09/22
301 Репутация
1 руководство автора
Команда
Portland State University, Team 1-1, Raible Spring 2022 Участник Portland State University, Team 1-1, Raible Spring 2022
PSUN-RAIBLE-S22S1G1
2 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 78
За последние 30 дней: 436
За всё время: 12,082
