Введение
Even the most well-made crochet blanket can start to look a little shabby after years of love and use. It's not uncommon for the yarn loops on a crochet project to unravel over time and a hole starts to form. Unless your blanket is literally hanging on by a thread, don’t throw it away yet! This guide will walk you through how to repair a hole in a crochet blanket so that it looks good as new.
Note: The exact repair method will depend on the construction of the blanket and the stitch pattern used. This guide works best for projects worked in three double-crochet clusters, also known as a granny stitch.
Выберете то, что вам нужно
Carefully unpick any torn or damaged stitches that have become separated from the main body of the blanket.
Secure any loose or dangling stitches by threading the bottom loops with stitch markers and clasping them closed.
After you’ve secured all of the loose stitches, it's time to fill in the hole. Join your new yarn to the first stitch on the bottom row.
Follow the original stitch pattern, starting at the bottom row and working from right to left.
When you're finished with a row, join with a slip knot and fasten off. Start the next row and repeat Steps 3 and 4.
When you reach the last row, take out the stitch markers in the top row of stitches.
Insert your hook through the bottom loops of the stitch. Yarn over and pull through all of the loops on your hook.
Repeat for the rest of the row.
4 участников успешно повторили данное руководство.
