Введение
This guide will show how to replace the air vent covers or grilles of an air conditioner. As the air conditioner is used for a long time, some dust will accumulate in the air vent covers of an air conditioner. This is when you will need to clean it or replace it.
Before beginning this guide, use a ruler to measure the length and width of the air conditioning vents. Then buy the corresponding size of the air conditioning vent cover online or in the store.
This guide is divided into two main parts. The first part is to remove the air vent and the second part is to replace it with a new one.
For safety, consider wearing a mask to prevent dust inhalation.
Выберете то, что вам нужно
Observe the structure of the air vent cover and the shape of the screws, and choose the right screwdriver.
Place a chair or ladder under the air outlet for easy access to the screws.
Use the screwdriver to loosen one screw on the right and one screw on the left side of the outlet vent cover.
Remove the air outlet from the wall by hand.
Take out the new air conditioner vent cover and confirm the correct orientation for replacement.
Place the new air conditioner cover into the wall and line the screw holes up with the holes in the wall.
Align the screws by hand first and tighten them gently.
Use a screwdriver to tighten the screws on the left and right sides in a clockwise direction.
