Введение
The battery in the Conair Trimmer (GMT15NCS) can stop working or not hold a charge as well. This guide will show how to replace this battery to give the trimmer longer life.
Выберете то, что вам нужно
Using a Phillips #0 screwdriver, remove the two screws holding the trimmer blade in place.
Using a Phillips #000 screwdriver, remove the casing screw at the bottom of the trimmer.
Remove the two screws holding the battery setup in place.
Take note of the position of the positive and negative terminals of the battery on the setup.
Using the soldering iron, desolder the battery at the connection to remove the battery from the setup.
To reassemble your device, solder the new 2.4 V battery into the setup, and follow the instructions in reverse.
2 участников успешно повторили данное руководство.
