Введение
The life of a trash can is dirty and rough. With those conditions, it can be expected that something will eventually break. Here is our guide to replacing the wheels of a 96 gallon toter trash can in the case that it does break. No experience is necessary, only a couple tools and these steps will get you a trash can that can roll again.
Выберете то, что вам нужно
Position the flathead screwdriver on the tab of the pal-nut in the center of the wheel.
Position the rubber mallet on top of the flathead screwdriver.
Hit the flathead screwdriver with the rubber mallet a couple times for each tab.
Use the rubber mallet to hit the back of the wheel and loosen the pal-nut.
If the pal-nut is stuck, use PB B'LASTER to spray on the pal-nut to break up any rust or corrosion.
Remove the pal-nut.
Remove the wheel with the pal-nut from the axle.
Slide the other wheel off of the trash can with the axle still attached.
Position the new pal-nut on the axle.
Use the rubber mallet and hit the pal-nut on the axle until it is secured.
Check that both sides are secured.
Flip the trash can back to the normal position.
Test the new wheels by rolling the trash can.
Now that your trash can is up and rolling again, you can now pat yourself on the back for a job well done!
Еще один человек закончил это руководство.
6 Комментариев
What size pal nuts on trash barrels
Putting wheels back on trash barrel.Need to replace pal nut and would like to know if there is a standard size to purchase
Hi there!
Upon looking at this specific replacement kit, the Pal-Nut size they used is 5/8”. Since you may have a different trash can with a different size axle, you should refer to any replacement kits made online and see what size Pal-Nut they use.
I am a 65 year grandmother and I replaced the wheels on my 20 year Toter with no issues, Found the repacement parts online. Proud of myself
