Введение
For travel, luggage is an indispensable item. During the trip, we must set a password for the suitcase to ensure the safety of the contents. But the password can be easily forgotten and neglected, so opening the suitcase is a more difficult thing. If you do forget the combination, follow this guide to reset the combination on your suitcase lock.
Set the suitcase down with the combination lock facing up.
Rotate the three gears together so that the grooved part of each gear faces the outside.
Correct: Gear faces the outside.
Gear faces the inside.
Remember the number of the three gears when the groove part is on the outside.
As of now the code number of the three gears is 181.
Add 5 to each of the three numbers. For example, my numbers are 181. After adding 5, the code to my lock would be 636.
Turn the numbers on the lock to 636, and then unlock the lock.
For example, if 636 does not work, try to add 6 to the three numbers. Then the code is 747 and attempt to unlock the lock. Continue to add 7, then 8 to try, until it can be opened.
After reading my guide, you will never encounter the problem that the suitcase cannot be opened without remembering the password. It can be solved anytime, anywhere.
3 участников успешно повторили данное руководство.
3 Комментариев
OMG! A big THANK YOU!!! It worked.
Amazing. This worked for me
It worked for me too
