How To Restring a Left Handed Guitar
  1. How To Restring a Left Handed Guitar, Guitar Strings: шаг 1, изображение 1 из 3 How To Restring a Left Handed Guitar, Guitar Strings: шаг 1, изображение 2 из 3 How To Restring a Left Handed Guitar, Guitar Strings: шаг 1, изображение 3 из 3
    • For each string, turn its tuning nob so that the string is slack, then uncoil it from the tuning peg.
  2. How To Restring a Left Handed Guitar: шаг 2, изображение 1 из 3 How To Restring a Left Handed Guitar: шаг 2, изображение 2 из 3 How To Restring a Left Handed Guitar: шаг 2, изображение 3 из 3
    • Untie the loops connecting the three thinner strings to the bridge and remove the strings.
    • Apply force away from the neck on the three thicker strings to unseat them from the bridge, then remove the strings.
    • Once each string is out, coil it up.
    • Make sure to be careful of the sharp edges on the strings.
    • For restringing a guitar, it is helpful to label the strings in some way such as placing each string on a labeled note card.
  3. How To Restring a Left Handed Guitar: шаг 3, изображение 1 из 3 How To Restring a Left Handed Guitar: шаг 3, изображение 2 из 3 How To Restring a Left Handed Guitar: шаг 3, изображение 3 из 3
    • To restring the guitar for a left-handed guitar player, flip the guitar so that the strings can be put on in reverse. The guitar's neck should face to the right when the guitar is sitting on your lap.
    • Pull each string through the bridge.
    • Retie each of the three thinner strings to the bridge.
    • Push each of the three thicker strings through the bottom of the bridge, locking it in place.
    • It is essential to make sure the strings are in the right order when restringing a guitar. The thickest string, the low E, should be highest from the ground when playing the guitar. The order goes: low E on the top, followed by A, D, G, B, and then high E, the thinnest string, on the bottom.
  4. How To Restring a Left Handed Guitar: шаг 4, изображение 1 из 3 How To Restring a Left Handed Guitar: шаг 4, изображение 2 из 3 How To Restring a Left Handed Guitar: шаг 4, изображение 3 из 3
    • Feed each string through the guitar and into its respective tuning peg, then tighten the tuning peg.
  5. How To Restring a Left Handed Guitar: шаг 5, изображение 1 из 3 How To Restring a Left Handed Guitar: шаг 5, изображение 2 из 3 How To Restring a Left Handed Guitar: шаг 5, изображение 3 из 3
    • Tune the guitar, using either your ears or an electric tuner.
    • If you want to improve the sound quality of the left-handed strung guitar, the guitar's nut can be replaced with a left-handed guitar nut for better sound quality.
    • If the guitar uses a saddle, the saddle and its slots can be adjusted to help the strings fit better. One could also buy and install a new left-handed bridge for the same effect.
Заключение
Enjoy your left-handed strung guitar!
Happy fixing!
Еще один человек закончил это руководство.
Joseph Chavez
Участник с: 08/22/22
121 Репутация
1 руководство автора
Команда
CSU Los Angeles, Team 3-10, Briggs Fall 2022 Участник CSU Los Angeles, Team 3-10, Briggs Fall 2022
CSULA-BRIGGS-F22S3G10
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 22
За последние 30 дней: 90
За всё время: 946
