Введение
This guide explains how to operate and care for an electric mandoline meat slicer so you can slice foods safely, keep your device clean, and prolong its lifespan. Always follow your manufacturer’s instructions and warranty guidelines for best results.
Выберете то, что вам нужно
Шаг 1 Remove the blade carefully
Maintenance is fairly simple but must be regular to maintain hygiene, which is important both for the user and the machine.
Remove the blade carefully.
Шаг 2 Clean slicer components
Use a damp cloth or cold water with mild detergent to wipe away any food residue from the blade and surfaces.
Apply a small amount of food safe lubricant or petroleum jelly on the gear to keep it running smoothly.
Шаг 4 Slicing cured or hard meats
Use a thin slicing setting to reduce extra pressure on the blade when cutting firm cured foods.
Шаг 5 Slicing softer ingredients
Lightly coat the slicer surface near the blade with cooking oil to prevent sticky foods from clinging.
Шаг 7 Slicing vegetables
Adjust thickness to slice potatoes, cucumbers, or radishes evenly without manual effort.
Using your meat slicer properly and maintaining it regularly helps preserve its cutting performance and extend its life. Always unplug before cleaning, keep the gear lubricated, and rely on professionals for complex repairs or sharpening. Follow your manufacturer’s instructions to stay within your warranty requirements and enjoy safe food preparation.
