How do I replace the wheels on my Tobago trolley?
Выберете то, что вам нужно
  1. How do I replace the wheels on my Tobago trolley?, Wheels: шаг 1, изображение 1 из 3 How do I replace the wheels on my Tobago trolley?, Wheels: шаг 1, изображение 2 из 3 How do I replace the wheels on my Tobago trolley?, Wheels: шаг 1, изображение 3 из 3
    • Open the trolley and unzip the lining.
  2. How do I replace the wheels on my Tobago trolley?: шаг 2, изображение 1 из 2 How do I replace the wheels on my Tobago trolley?: шаг 2, изображение 2 из 2
    • Unscrew the 4 marked screws with a Phillips screwdriver.
    • When attaching the new wheels, take care not to over tighten the screws.
    • Use the flat-blade screwdriver to remove the 2 washers.
    • Removing the wheelhouse from the trolley.
    • Pinch off the two remaining rivets with the tongs.
  3. How do I replace the wheels on my Tobago trolley?: шаг 6, изображение 1 из 3 How do I replace the wheels on my Tobago trolley?: шаг 6, изображение 2 из 3 How do I replace the wheels on my Tobago trolley?: шаг 6, изображение 3 из 3
    • Remove the other 2 rivets on the outside of the trolley using the flat-blade screwdriver. Then remove the wheelhouse from the trolley.
    • When attaching the new wheelhouse, take care not to over tighten the screws.
Заключение
Follow the instructions in reverse order to finish the repair.
VAUDE Reparaturteam
Участник с: 02/22/16
6 255 Репутация
Автор 32 руководств
Команда
Vaudesport Участник Vaudesport
Community
3 членов
Автор 96 руководств
3 Комментариев
Dear Vaude, I have a Module 60 where the airline has managed to snap of a wheel recently. I am in contact with the UK supplier of Vaude parts, but is the repair similar to above and therefore I need to order the right hand side plastic/wheel? Thank you for any help.
JANE D - Ответить
Dear Jane, yes, you can use this repair guide also for your Module Trolley. You will get a set of wheels, you so can change both if you want.
VAUDE Reparaturteam -
Dear Vaude
I have a trolley Samoa, and it seems I can't get replacements like for the Tobago. Any idea how I could find wheels to replace the broken ones?
Rollo Launche - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 20
За последние 30 дней: 88
За всё время: 4,690
