Введение
Accessing the internal components of the HP 15-R011DX is the beginning to find and solve the majority of all problems in the laptop. You’re going to need a Phillips #1 screwdriver and a safe place to put small pieces such as the screws and other components so to prevent loss.
Выберете то, что вам нужно
Flip the laptop over to reveal screw locations.
Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
Remove the DVD drive from the laptop.
Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
Flip the laptop and open.
Detach the keyboard by prying it free from the laptop using a spudger.
Disconnect the keyboard ribbon cable.
Disconnect the two narrow ribbon cables to the left of the keyboard connection.
Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
Pry open the plastic casing using a spudger.
2 участников успешно повторили данное руководство.
