Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Locate the wiring harness bundle, which exits the firewall underneath the brake booster.
Identify the auxiliary wire, which is folded and taped to either the wiring harness or the fire wall.
Use a knife to cut the tape away from the wire and unravel it.
Place the ring terminal (washer end) of the wire on the right post located at the front of the battery.
Place the 10 mm washer on the post.
Tighten the washer using a 10 mm wrench, crescent wrench, or pliers.
After hooking up the wire, check to make sure the 40 amp fuse is installed for the auxiliary pin.
13 участников успешно повторили данное руководство.
6 Комментариев
This sends constant power to the trailer. What if I wanted to make that power switched by the ignition so when the key is off I can be confident that the trailer won't kill my truck battery? I know I can just unplug the trailer harness or pull this fuse to stop it, but That might be easy to forget to do.
Eric, did you ever get an answer to your inquiry about killing the power to the trailer when the key is in the off position?
It’s not a break booster, it is a brake booster. If you are going to be an author, you should know the meaning of the words you use.
Never fails some troll somewhere..
“Words have meaning” geez Cyber Warrior. Tough talk from a distance. ?
nshourds -
