How to Add a Hole in a Leather Belt
Выберете то, что вам нужно
  1. How to Add a Hole in a Leather Belt, How to Add a Hole in a Leather Belt: шаг 1, изображение 1 из 1
    • Make sure the leather belt is clean by wiping it down with water and drying it before working on it beforehand to get rid of any excess dirt or grime.
  2. How to Add a Hole in a Leather Belt: шаг 2, изображение 1 из 1
    • Find a flat and durable surface to work on, preferably a wooden work table. If that’s not available, then use a good sized wooden block to work on.
  3. How to Add a Hole in a Leather Belt: шаг 3, изображение 1 из 1
    • Using a measuring tape, measure the distance between each of the existing holes to figure out the distance to place your new hole.
  4. How to Add a Hole in a Leather Belt: шаг 4, изображение 1 из 1
    • Mark where you want the hole with either a pen or indent using the pin punch. Mark as many as you see fit before continuing onto the next step.
  5. How to Add a Hole in a Leather Belt: шаг 5, изображение 1 из 1
    • Align the pin punch where you marked the hole.
    • Make sure to tighten the grip on the pin before hammering onto the marked area. Continue this for all the other hole marks.
  6. How to Add a Hole in a Leather Belt: шаг 6, изображение 1 из 1
    • Push the pin all the way through the hole to make sure the hole is fully formed.
  7. How to Add a Hole in a Leather Belt: шаг 7, изображение 1 из 1
    • Clean off any stray leather bits left from the hole placement using a razor blade.
Заключение
Once you complete all your steps, make sure to congratulate yourself on your new belt! Now you can hold up anything you need without any issues.
Feliza Castillo
Участник с: 05/24/23
195 Репутация
1 руководство автора
Команду
York University, Team A-2, Allen Summer 2023 Участник York University, Team A-2, Allen Summer 2023
YORK-ALLEN-SU23SAG2
1 член
Автор 2 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 5
За последние 30 дней: 25
За всё время: 484
