Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
How to Apply Custom-cut Adhesive Strips
Выберете то, что вам нужно
  1. How to Apply Custom-cut Adhesive Strips, Identify the adhesive strips: шаг 1, изображение 1 из 1
    • Look over your pre-cut adhesive strips and figure out what they are used for.
    • Here are some common adhesives used in a phone repair, and examples of what they may look like:
    • Screen or back cover adhesives—usually the shape of the device
    • Back cover support adhesives—these will match the contours of components pressed against the back cover
    • Battery adhesives—normally a rectangular perimeter roughly the shape of the phone's battery
    • Component adhesives—they will be contoured to match the various components such as cameras and fingerprint sensors they are designed for
    • You usually want to apply the screen or back cover adhesives last. Be sure to apply all component adhesives beforehand, and if possible, test your repair before sealing up the device.
  2. How to Apply Custom-cut Adhesive Strips, Prepare the surface: шаг 2, изображение 1 из 3 How to Apply Custom-cut Adhesive Strips, Prepare the surface: шаг 2, изображение 2 из 3 How to Apply Custom-cut Adhesive Strips, Prepare the surface: шаг 2, изображение 3 из 3
    • To ensure a good adhesive bond, thoroughly clean the adhesion surfaces. This may take some time, but the results are worth the effort.
    • Remove large chunks of adhesives with your fingers, spudger, plastic opening tool, or tweezers.
    • Do not use metal tools if you are cleaning display panels or glass covers, as the tools may scratch the surface.
    • Use adhesive remover or high concentration (>90%) isopropyl alcohol to remove residue from metal surfaces. Wipe in one direction with a lint-free cloth or coffee filter until all the adhesive residue is gone.
    • While isopropyl alcohol is generally safe to use on electronics, they will dissolve certain foam adhesives. Be careful to contain the alcohol when cleaning, and allow it to completely evaporate from the device before re-assembly.
  3. How to Apply Custom-cut Adhesive Strips, Remove the adhesive liner: шаг 3, изображение 1 из 3 How to Apply Custom-cut Adhesive Strips, Remove the adhesive liner: шаг 3, изображение 2 из 3 How to Apply Custom-cut Adhesive Strips, Remove the adhesive liner: шаг 3, изображение 3 из 3
    • Generally, adhesives strips have a colored side and a non-colored (paper or clear plastic) side. The non-colored side of the strip should be applied first.
    • Before you peel any liners, locate the surface the non-colored side should stick to.
    • To make adhesive application easier, you can align the strip to its intended position on the phone, then tape one edge down to hold the strip in place. This will allow you to peel away the liners and expose the adhesive without losing alignment.
    • Once you have a good idea how the adhesive strip fits on the surface, peel the non-colored liner off.
    • If you are applying a back cover or screen adhesive, you may need to peel out the unnecessary center portion of the adhesive strip:
    • Carefully peel away the center portion of both the white (paper) and black (adhesive) layers, starting with the U-shaped cutout (if present).
    • Peel off and discard the remaining paper liner, exposing the adhesive underneath.
  4. How to Apply Custom-cut Adhesive Strips: шаг 4, изображение 1 из 3 How to Apply Custom-cut Adhesive Strips: шаг 4, изображение 2 из 3 How to Apply Custom-cut Adhesive Strips: шаг 4, изображение 3 из 3
    • Hold the exposed strip by its tabs and carefully line up a long edge of the adhesive to the edge of the back cover.
    • Be very careful with alignment. Most of the time, you cannot peel and re-apply the adhesive strip if it's misaligned.
    • Set the adhesive onto the surface and press it firmly onto the surface with your fingers.
    • Peel away the colored liner from the adhesive strip to expose the remaining adhesive side.
  5. How to Apply Custom-cut Adhesive Strips: шаг 5, изображение 1 из 3 How to Apply Custom-cut Adhesive Strips: шаг 5, изображение 2 из 3 How to Apply Custom-cut Adhesive Strips: шаг 5, изображение 3 из 3
    • Press the other surface firmly against the exposed adhesive for 20-30 seconds.
    • If you are adhering a screen or a back cover, stack some books on top for a few hours to help the adhesive bond.
    • Be careful to apply even pressure across the surface. Take note of any camera bumps and avoid applying pressure solely on them.
Заключение
If properly applied, the adhesive should work reliably for a long time.
The repair may not restore the device’s water resistance. Be careful not to expose the device to liquids.
97 участников успешно повторили данное руководство.
Arthur Shi
Участник с: 01/03/18
248 451 Репутация
Автор 503 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 16 573 руководств
8 Комментариев
Diese Anleitung sollte im Akku-Tausch Tutorial verlinkt sein und auch in der Produktbeschreibung. Ich habe diesen Artikel erst gefunden, nachdem ich die Rückseite schon befestigt hatte (zum Glück richtig).
Andreas Voss - Ответить
Although obvious to anyone who has used this type of strip, I didn't realize it until my first experience gluing a screen into my phone: the adhesive is ONLY the black goo attached to the strips. Once you peel off the clear side, place the strip and then peel off the coloured side, all that's left is the black goo, hopefully exactly where it needs to be. Mine could be carefully re-aligned with tweezers as necessary before setting the screen into place.
Chris - Ответить
What's the popular recommendation regarding how long to leave weight on these pre-cut adhesive strips?
It merely says 'a few hours'?
Is it okay to check on it or is it like opening the oven door?
Eldon - Ответить
It's okay to check, and 2 hours is usualy plenty enough.
Paul Sorba -
If you have any OLED display, DO NOT put books on it!!! Unlike LCDs, some Hard OLEDs cannot handle the pressure. If you have bought a display from ifixit they will also not warranty it and consider it user damage!!! That last section need to put in a warning for OLEDs.
kuronokagami - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 43
За последние 7 дней: 344
За последние 30 дней: 1,569
За всё время: 100,696
