How to Bind a Book Spine
Выберете то, что вам нужно
  1. How to Bind a Book Spine, How to Bind a Book Spine: шаг 1, изображение 1 из 1
    • First, grab the book you would like to fix.
  2. How to Bind a Book Spine: шаг 2, изображение 1 из 1
    • Then, open the book to where you have the most access to the exposed inner spine.
  3. How to Bind a Book Spine: шаг 3, изображение 1 из 1
    • Shake up the glue before removing the cap.
    • Then, test glue on a piece of paper before placing it on the spine of the book. It should be about the consistency of Elmer's glue.
  4. How to Bind a Book Spine: шаг 4, изображение 1 из 1
    • Place the glue along the spine opposite of the cover. Make sure you are distributing glue evenly.
    • You may also choose to use a paint brush to make sure area is completely covered with glue.
    • Glue is runny; use with caution.
  5. How to Bind a Book Spine: шаг 5, изображение 1 из 1
    • After placing the glue, wrap the cover tightly around the book.
    • Firmly drag your fingers down the spine of the book to avoid any air pockets.
    • Remove any excess glue with a tissue.
    • For the demonstration we held the book as shown. You may also choose to place something on top of the book, such as a paperweight or another book, and let it sit for 30 to 40 minutes.
  6. How to Bind a Book Spine: шаг 6, изображение 1 из 1
    • After the glue is dry, you should be able to lightly tug on the pages without any movement.
    • If movement occurs then allow the glue an additional 10 to 15 minutes to dry. Once dry, you've completed your book repair.
Заключение
2 участников успешно повторили данное руководство.
Britne Misner
Участник с: 09/30/16
149 Репутация
1 руководство автора
Команда
Missouri Western, Team 1-13, Adkins Fall 2016 Участник Missouri Western, Team 1-13, Adkins Fall 2016
MWSU-ADKINS-F16S1G13
2 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 37
За последние 30 дней: 80
За всё время: 1,235
