How to Calibrate Steam Deck Triggers
  1. How to Calibrate Steam Deck Triggers, Open Konsole: шаг 1, изображение 1 из 2 How to Calibrate Steam Deck Triggers, Open Konsole: шаг 1, изображение 2 из 2
    • If you're not already in desktop mode, navigate to the Steam MenuPower, and select Switch to Desktop.
    • If you don't have a keyboard plugged into your Steam Deck, you'll need to use the on-screen keyboard.
    • Press the Steam Button + X to enable the on-screen keyboard.
    • Trigger calibration is done within a terminal window using SteamOS's console, named Konsole.
    • From the Search menu, search for and open Konsole.
    • If you need to, move the Konsole window so your on-screen keyboard doesn't obscure it.
  2. How to Calibrate Steam Deck Triggers, Start the trigger calibration: шаг 2, изображение 1 из 1
    • Within Konsole, type trigger_cal.
    • Alternatively, type trig and then press Tab to auto-complete.
    • Press Enter.
  3. How to Calibrate Steam Deck Triggers, Perform the trigger calibration: шаг 3, изображение 1 из 2 How to Calibrate Steam Deck Triggers, Perform the trigger calibration: шаг 3, изображение 2 из 2
    • The software will first calibrate the triggers' non-depressed resting position.
    • Ensure that neither trigger is depressed. Press Enter.
    • The software will now calibrate the triggers' fully-depressed position.
    • Tap on a blank desktop area to move the cursor off of the Konsole window. Make sure Konsole isn't in focus.
    • Gently press down each trigger until they bottom out.
    • Don't apply too much force or the triggers could be incorrectly calibrated.
    • Tap on the Konsole window to bring focus back to it. Press Enter.
    • That's it! Your triggers are now calibrated. The terminal should say "Trigger calibration successful."
Заключение
Click here to return to the left trigger replacement guide. Click here to return to the right trigger replacement guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
3 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
104 737 Репутация
Автор 338 руководств
Команда
iFixit Участник iFixit
Staff
141 членов
Автор 16 253 руководств
10 Комментариев
Do you need to enable developer mode or download anything to get this working? All I get is 'command not found' when I try to run trigger_cal_v1_1.
sudoWiz - Ответить
Same, hoping this gets looked at and resolved.
Philip Kellett - Ответить
all i get is :permission denied" anytime i try this, please update the guide
Garrett Hart - Ответить
trigger_cal is located in /usr/bin/trigger_cal but is not executable. Here's what I did:
cp /usr/bin/trigger_cal ~/
chmod u+x
./trigger_cal
Ben Jackel - Ответить
This is an incomplete guide when it doesn't explain the permission error when executing trigger_cal
Tim Mok - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 127
За последние 30 дней: 682
За всё время: 11,267
