Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Place the picker tool under the staple
Begin to lift the staple off of the frame by moving the picker tool down towards the table.
Once the staple is halfway lifted, use the pliers to completely lift the staple from the frame.
Repeat steps 2-3 to remove the rest of staples.
Measure out the amount of canvas that is needed to cover the edges of the frame.
Once measured, make a small cut in the corner.
Use your hands to rip off the excess fabric.
Fold one side of the canvas fabric over the edge of one of the long sides of the frame.
While holding the canvas down, use the staple gun to place one staple in the middle
Go over to the other side of the frame and use the canvas pliers to grab the canvas fabric. To tighten canvas fabric, begin by holding the pliers at a 45 degree angle then moving the pliers down towards the table.
While holding the fabric down, place a staple in the middle of that side of the frame.
Continue Step 7 on the two short sides of the frame.
Choose one of the long sides of the frame and begin stapling from the center to about 3 inches away from the corner using the same canvas plier technique from step 7. Then repeat on other long side.
Next, repeat this stapling process on the two short sides
Trim the corner of the fabric to make folding easier.
Repeat on the other three corners.
Choose one corner of the frame and tuck excess fabric inside the fold.
Holding tightly onto the fabric, pull the fold up and over the the edge of the frame. Staple to secure both sides of the corner.
2 участников успешно повторили данное руководство.
