How to Change an Indoor Doorknob Handle
Выберете то, что вам нужно
  1. How to Change an Indoor Doorknob Handle, How to Change an Indoor Doorknob Handle: шаг 1, изображение 1 из 1
    • Parts: (in order from left to right)
    • Short Screws
    • Latch mechanism with latch face
    • Long screws
    • Door knob with peg and screw holes (inside of the room)
    • Door knob with screw holes (outside of the room)
  2. How to Change an Indoor Doorknob Handle: шаг 2, изображение 1 из 1
    • Face the inside of the knob, you should see two Phillips head screws on either side of the central knob.
  3. How to Change an Indoor Doorknob Handle: шаг 3, изображение 1 из 1
    • Unscrew both long screws.
  4. How to Change an Indoor Doorknob Handle: шаг 4, изображение 1 из 1
    • Remove the door knob on both sides of the door.
  5. How to Change an Indoor Doorknob Handle: шаг 5, изображение 1 из 1
    • You will see the latch face plate (the rectangular piece of metal) where the latch of the door knob is located.
  6. How to Change an Indoor Doorknob Handle: шаг 6, изображение 1 из 1
    • Unscrew the two short screws on the latch face plate.
  7. How to Change an Indoor Doorknob Handle: шаг 7, изображение 1 из 1
    • Remove the latch face plate and latch mechanism.
  8. How to Change an Indoor Doorknob Handle: шаг 8, изображение 1 из 1
    • Push the new latch mechanism with latch face plate into the door.
    • The slanted side of the latch mechanism will be facing the direction that the door closes.
  9. How to Change an Indoor Doorknob Handle: шаг 9, изображение 1 из 1
    • Screw in both short screws of the latch face plate.
  10. How to Change an Indoor Doorknob Handle: шаг 10, изображение 1 из 1
    • Insert the door knob that goes on the inside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  11. How to Change an Indoor Doorknob Handle: шаг 11, изображение 1 из 1
    • Align the door knob that goes on the outside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  12. How to Change an Indoor Doorknob Handle: шаг 12, изображение 1 из 1
    • Screw in both long screws on both sides of the door knob.
  13. How to Change an Indoor Doorknob Handle: шаг 13, изображение 1 из 1
    • Turn the door knob to test your work.
Заключение
To put the old door knob back on or to change to a different door knob repeat steps from the beginning.
6 участников успешно повторили данное руководство.
Mallory
Участник с: 02/19/15
220 Репутация
1 руководство автора
Команда
CSU Stanislaus, Team 1-1, Moberly Spring 2015 Участник CSU Stanislaus, Team 1-1, Moberly Spring 2015
CSUS-MOBERLY-S15S1G1
4 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 24
За последние 30 дней: 67
За всё время: 9,305
