How to Check Resistance of Suzuki Wagon R Temperature Sensor
Выберете то, что вам нужно
      • Be careful when working on Engine! Dont test when engine is running. Wait for engine to cool down!!
      Спросите у FixBot
      Добавить комментарий
    1. How to Check Resistance of Suzuki Wagon R Temperature Sensor, Open the Bonnet to access Engine Compartment: шаг 2, изображение 1 из 2 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Open the Bonnet to access Engine Compartment: шаг 2, изображение 2 из 2
      • Pull the bonnet release handle located on the outboard side of the driver's side of the instrument panel. This will disengage the bonnet lock halfway
      • Push the under-bonnet release lever sideways with your finger. While pushing the lever, lift up the bonnet
      • Continue to lift up the bonnet until it is high enough to support with the prop rod
      • Make sure the bonnet is fully closed and latched before driving. If it is not,it can fly up unexpectedly during driving, obstructing your view and resulting in an accident.
      Спросите у FixBot
    2. How to Check Resistance of Suzuki Wagon R Temperature Sensor, Unplug the Plug connection: шаг 3, изображение 1 из 2 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Unplug the Plug connection: шаг 3, изображение 2 из 2
      • The component Intake air temperature sensor is located in the intake pipe just after the Air Filter.
      • Unplug the plug connection by pressing the release tab
      Спросите у FixBot
    3. How to Check Resistance of Suzuki Wagon R Temperature Sensor, Measure Resistance: шаг 4, изображение 1 из 3 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Measure Resistance: шаг 4, изображение 2 из 3 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Measure Resistance: шаг 4, изображение 3 из 3
      • Turn the knob in the multimeter to set the test to Ohms/Resistance
      • Connect the terminal 1 and 2 of the component Intake air temperature sensor to Multimeter positive and negative
      • The set value at ignition on and engine cold is 1.3KOhms
      Спросите у FixBot
Заключение
5 человек успешно провели ремонт по этому руководству.
ananda
Участник с: 03/18/15
238 Репутация
1 руководство автора
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 64
За всё время: 6,443
