Введение
Whether you've stepped in a puddle or your shoes have gotten dirty from everyday wear, use this simple guide to help restore them to like-new condition!
Before beginning this guide, set up a well-lit space, preferably outdoors, to ensure clear visibility of the shoes. If possible, avoid using bowls or containers that can break, as shattered glass can pose a risk of injury.
Выберете то, что вам нужно
Set up two bowls, dish soap, and a brush.
One bowl will be used to clean the shoes and the other to clean the laces.
Identify which parts of the shoes that need cleaning.
Fill both bowls with water.
Add a small amount of dish soap to make the cleaning solution.
Remove the laces from both shoes
Place the laces in the second bowl filled with the cleaning solution.
Brush the shoes in a circular motion using the cleaning solution.
Rinse the brush regularly to keep the shoe soaked.
Clean all parts of the shoe to ensure a thorough cleaning.
Place the shoes and laces outside in the sun to dry completely.
Once they’re fully dry, relace the shoes.
Pour out the cleaning solution from the bowls.
The bowls can be reused later for cleaning other shoes.
Hopefully, this will be able to clean your Air Jordans 11's or any Jordans at all.
Thank You so much.
Thank You so much.
