Введение
If you are experiencing rough idle, stumbling engine on acceleration, and or trouble shifting into higher gears then it may be time to clean your throttle body.
Whether there are issues or not, the throttle body should be cleaned every 30,000 miles.
Follow this video tutorial by YouTuber NutzAboutBolts to do the cleaning job yourself.
Выберете то, что вам нужно
Видеоинструкции
Почти готово!
Заключение
Один комментарий
After he takes the air filter housing box out and manually moves the throttle plate open… could i use seafoam motor treatment on there as well to clean the entire upper engine head ?
Jeff Richter - Ответить
