How to Clean Your Car Battery Terminals
Выберете то, что вам нужно
  1. How to Clean Your Car Battery Terminals, How to Clean Your Car Battery Terminals: шаг 1, изображение 1 из 3 How to Clean Your Car Battery Terminals, How to Clean Your Car Battery Terminals: шаг 1, изображение 2 из 3 How to Clean Your Car Battery Terminals, How to Clean Your Car Battery Terminals: шаг 1, изображение 3 из 3
    • TURN OFF ENGINE, put it in park, and engage the emergency brake. Do not work on the battery with the car on.
    • Pull the hood release in the bottom left of the driver's side of your car.
    • Release the hood safety catch inside the hood.
    • Lift and secure the hood with the hood prop.
    • Organize Required Tools: Wire Brush, Small Combination Wrench, Tech Wipes or Used Rag.
    • By following these steps, you can effectively clean your car battery and maintain a reliable electrical system in your vehicle. Remember to prioritize safety and don't be afraid to ask someone for help.
  2. How to Clean Your Car Battery Terminals: шаг 2, изображение 1 из 3 How to Clean Your Car Battery Terminals: шаг 2, изображение 2 из 3 How to Clean Your Car Battery Terminals: шаг 2, изображение 3 из 3
    • Put on personal protective equipment, including gloves and safety goggles, to shield yourself from battery acid and debris.
    • Carefully inspect the battery for any signs of damage, leaks, or cracks. If the battery is damaged, it should be replaced instead of repaired or cleaned.
    • Use a small adjustable wrench to loosen and remove the negative (-) battery cable first.
    • Handle your tools carefully when near the battery to prevent shock or arcing.
    • Remove the positive (+) cable. Set the cables aside, ensuring they don't accidentally touch the battery terminals or any metal surfaces of the vehicle.
  3. How to Clean Your Car Battery Terminals: шаг 3, изображение 1 из 3 How to Clean Your Car Battery Terminals: шаг 3, изображение 2 из 3 How to Clean Your Car Battery Terminals: шаг 3, изображение 3 из 3
    • Spray the battery cleaner on the terminals and wait a few minutes. Use the wire brush or battery terminal brush to thoroughly scrub corrosion and debris from the metal until the terminals are clean and shiny.
    • Clean inside the battery cable heads which connect to the battery terminals as well.
    • Pay special attention to any visible corrosion or white or greenish deposits. Remove any stubborn corrosion or buildup.
  4. How to Clean Your Car Battery Terminals: шаг 4, изображение 1 из 3 How to Clean Your Car Battery Terminals: шаг 4, изображение 2 из 3 How to Clean Your Car Battery Terminals: шаг 4, изображение 3 из 3
    • Spray CPC on the battery terminals and battery cable heads.
    • DO NOT ingest or get it into your eyes.
    • Apply dielectric grease to battery terminals generously.
    • Coat the washers in dielectric grease if there is any left.
    • Slip washers onto the battery terminals.
  5. How to Clean Your Car Battery Terminals: шаг 5, изображение 1 из 2 How to Clean Your Car Battery Terminals: шаг 5, изображение 2 из 2
    • Use an adjustable wrench to reconnect the positive (+) cable to the positive (+) battery terminal and tighten it securely.
    • Use an adjustable wrench to reconnect the negative (-) cable to the negative (-) battery terminal and tighten it securely.
    • Double-check that all connections are secure.
    • Account for all of the tools you used and put them away.
    • Start your car to ensure it starts without any issues. Check that all electrical components, such as lights and radio, are functioning correctly.
Заключение
  1. Reattach the Battery Hold-Down: If your car has a battery hold-down bracket or strap, secure the battery in place. Tighten the bracket or strap to prevent any movement or vibration during driving. If you did not have a battery hold-down skip this step.
  2. Apply Terminal Protection (OPTIONAL):
    • Apply a thin layer of battery terminal grease or petroleum jelly to both the positive and negative terminals. This helps prevent corrosion on the terminals and ensures good electrical contact.
    • After application of grease, slide on anti corrosion washers over battery terminals.
  3. Reconnect the Battery Terminals:
    • Positive Terminal (+): Reconnect the positive (+) battery terminal first. Slide the cable connector over the positive terminal post and tighten the nut securely. Use a wrench to ensure a snug fit, but avoid over-tightening, which could damage the terminal.
    • Negative Terminal (-): Next, reconnect the negative (-) battery terminal. Attach the cable connector to the negative terminal post and tighten the nut securely. Again, use a wrench to ensure a snug fit without over-tightening.
    • Attach Battery Terminal Covers (OPTIONAL): If applicable, any ordered battery covers may be attached if ordered.
  4. Double-Check Connections:
    • Verify that all connections are secure. Ensure the battery is firmly held in place, and the terminals are tightly connected.
  5. Turn On the Vehicle:
    • Start the car to ensure it starts without any issues. Check all electrical components, such as lights, radio, and air conditioning, to make sure they are functioning correctly. This will confirm that the battery is properly reassembled and connected
Еще один человек закончил это руководство.
Job Johnson
Участник с: 09/27/23
145 Репутация
1 руководство автора
Команда
University of Arizona, Team 6-10, Cools Stephens Fall 2023 Участник University of Arizona, Team 6-10, Cools Stephens Fall 2023
ARIZONA-COOLS STEPHENS-F23S6G10
1 член
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 24
За последние 30 дней: 120
За всё время: 296
