How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror
Выберете то, что вам нужно
  1. How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror, How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 1, изображение 1 из 1
    • Dispense an arbitrary amount of alcohol into a bowl.
    • Take a pipette and submerge its narrow end into the alcohol, then squeeze and release the bulb end with your fingers to extract alcohol.
    • Firmly squeeze and release the bulb end so the pipette fills to the 1 milliliter mark.
    • Transfer and dispense the pipette's alcohol into a separate bowl.
    • Extract 24 milliliters of alcohol into a separate bowl.
  2. How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 2, изображение 1 из 1
    • Pour an arbitrary amount of distilled water into a bowl.
    • Extract 6 milliliters of distilled water and transfer them into the same bowl with the 24 milliliters of alcohol.
  3. How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 3, изображение 1 из 1
    • Stir the alcohol-distilled water solution with the pipette.
    • Transfer the solution from the bowl to the spray bottle via pipette.
    • You could carefully pour the solution straight into the spray bottle.
    • Screw on the spray bottle cap.
  4. How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 4, изображение 1 из 2 How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 4, изображение 2 из 2
    • Locate the back of your telescope and notice the 3 pairs of screws with one screw sticking further out than the other in each pair.
    • Remove the three 19.1 mm lower resting screws from your telescope using a Phillips #1 screwdriver.
    • While unfastening the 3rd screw, palm the back panel of your telescope so it doesn't fall off unexpectedly.
    • Carefully pull back the loose panel exposing the primary mirror and set it aside.
  5. How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 5, изображение 1 из 3 How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 5, изображение 2 из 3 How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 5, изображение 3 из 3
    • Lay the back panel flat on a table with the mirror facing upwards and grab a camel hair brush.
    • To remove dust particles, lightly brush the mirror's surface starting in the center and pulling out towards the edge of the mirror.
    • Perform center to edge strokes 360 degrees around the mirror.
  6. How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 6, изображение 1 из 1
    • To remove tougher build up, take the spray solution and disperse 4-5 sprays onto a tissue paper.
  7. How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 7, изображение 1 из 3 How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 7, изображение 2 из 3 How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 7, изображение 3 из 3
    • Applying minimal pressure, mimic the same strokes as the brush by pulling the moist side of the tissue from the center to the edge of the mirror.
    • Perform these strokes 360 degrees around the mirror.
    • If build up still remains, repeat the motions above with more pressure but just enough to remove the build up.
  8. How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 8, изображение 1 из 2 How to Clean a Celestron PowerSeeker 127EQ Telescope's Primary Mirror: шаг 8, изображение 2 из 2
    • Remove any remaining dust particles that accumulated since the tissue by using the brush to stroke the mirror as before.
Заключение
To reassemble your device, follow instruction 4 in reverse order. Line up and screw all the screws into their screw holes so the bottoms of the screw heads lay flush with the back panel of your telescope.
Еще один человек закончил это руководство.
Ethan Powell
Участник с: 07/04/23
184 Репутация
1 руководство автора
Команда
Austin Community College, Team 1-6, Meigs Summer 2023 Участник Austin Community College, Team 1-6, Meigs Summer 2023
AUSTINCC-MEIGS-SU23S1G6
1 член
Автор 1 руководств
Один комментарий
@ethan_powell awesome guide! Just purchased a telescope to get ready for retirement :-) Quick question. I am with the understanding to stay away from 70% isopropyl alcohol because of it contains 30% of impurities, which could lead to streaks. I was told to use at least 90% or higher, and to dilute isopropyl alcohol over 96% with distilled water, to prevent early evaporation. What is your thought on this?
oldturkey03 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 12
За последние 30 дней: 28
За всё время: 285
