Введение
This guide is for users who are unfamiliar with disassembling the Dirt Devil Vacuum Cleaner model. This includes the basic steps on how to disassemble the vacuum model, clean the roller brush, and reassemble the vacuum. These simple instructions are for users who have a problem with the vacuum roller brush not spinning and want a quick repair on their own. The special requirement of this guide is to know how to loosen the screw on the bottom plate and tighten the screw.
Выберете то, что вам нужно
Lay the vacuum cleaner on the floor so that the bottom of the vacuum is facing upwards.
Check if the belt is attached.
Check if the motor part is well inserted with the belt attached to the roller brush.
Еще один человек закончил это руководство.
4 Комментариев
Might be helpful if you showed where all 8 screws are seeing how I can only find 6 and cannot get it open!
in the front there are to wheels, pop them out and you will see the other 2 screws
my power express lite only has 6 screws as well. I cannot get it open, I'm afraid it will break if I keep prying.
