Введение
This comprehensive guide provides step-by-step instructions to effectively clean the glass oven door of your GE appliance oven model JCBS250DM2WW. Whether your oven door glass has accumulated grease, food residue, or unsightly stains, this tutorial will walk you through the process of not only cleaning it but also safely opening the oven door to access the glass and ensuring it is securely closes afterward. With clear and concise directions, you'll be able to restore the transparency and cleanliness of your oven door glass, ensuring your oven looks and functions its best. Follow along to the easy steps to achieve a sparkling clean oven door.
Before beginning this guide, make sure that your oven is off and cool if you have used it recently and unplug the oven from the power supply.
Выберете то, что вам нужно
Disconnect the oven from the power supply.
Open the oven door.
Use the the 3/32" Allen wrench to remove the two 8mm x 2mm M2 hex screws.
Dip the soft sponge in the soapy water and gently rub the glass until there is no grease or spots.
Use a clean cloth to wipe the glass off so there are no streaks.
Use the sponge to clean the glass with a soap solution and soft clean cloth to wipe the glass off.
For any hard remaining stains, make a paste of baking powder and water.
Mix three table spoons of baking power and two table spoons of water.
Use the sponge to apply it on the hard stains and let it rest for two minutes.
Use a soft cloth to wipe off the paste from the glass.
To reassemble the door, press bottom and top part of the door together.
Replace the hex screws using the 3/32" Allen wrench.
Еще один человек закончил это руководство.
