How to Clean and Apply Thermal Compound
Выберете то, что вам нужно
  1. How to Clean and Apply Thermal Compound, How to Clean and Apply Thermal Compound: шаг 1, изображение 1 из 1
    • Saturate a cotton swab with isopropyl alcohol, and remove the thermal compound from the thermal plates on your component using gentle circular motions.
    • As the cotton swab becomes saturated with thermal compound, discard and continue with a freshly dipped cotton swab. The compound plate is clean when the cotton swabs come away clean.
  2. How to Clean and Apply Thermal Compound: шаг 2, изображение 1 из 2 How to Clean and Apply Thermal Compound: шаг 2, изображение 2 из 2
    • Repeat the same cleaning process from the previous step on the matching thermal plates on the motherboard.
    • Avoid touching the thermal compound areas once they are clean. Dirt or oil on either surface can disrupt cooling performance and lead to overheating or thermal throttling.
  3. How to Clean and Apply Thermal Compound: шаг 3, изображение 1 из 2 How to Clean and Apply Thermal Compound: шаг 3, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Apply a small amount of thermal compound, about the size of a grain of rice, on the corner of each the cleaned thermal plates on the motherboard.
    • Using a clean plastic card, carefully spread the thermal compound evenly over the surfaces of each thermal plate.
    • You need to clean the thermal plates on both the component and the motherboard, but you only need to apply thermal paste on the motherboard thermal plates.
    • Avoid applying too much or too little thermal compound, as it can impede crucial heat transfer. Once spread, the compound should be about as thick as a single sheet of paper.
  4. How to Clean and Apply Thermal Compound: шаг 4, изображение 1 из 1
    • Gently re-seat your component, making sure that the thermal plates align correctly.
Заключение
Please refer to the previous guide in order to reassemble your device.
4 участников успешно повторили данное руководство.
Reina Godeck
Участник с: 10/16/17
741 Репутация
Автор 5 руководств
Команда
UW Tacoma, Team S3-G5, Liner Fall 2017 Участник UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 членов
Автор 18 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 15
За всё время: 2,235
