Выберете то, что вам нужно
Saturate a cotton swab with isopropyl alcohol, and remove the thermal compound from the thermal plates on your component using gentle circular motions.
Repeat the same cleaning process from the previous step on the matching thermal plates on the motherboard.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Apply a small amount of thermal compound, about the size of a grain of rice, on the corner of each the cleaned thermal plates on the motherboard.
Using a clean plastic card, carefully spread the thermal compound evenly over the surfaces of each thermal plate.
Gently re-seat your component, making sure that the thermal plates align correctly.
Please refer to the previous guide in order to reassemble your device.
4 участников успешно повторили данное руководство.
