How to Clean and Sharpen your Wahl Hair Clippers
Выберете то, что вам нужно
  1. How to Clean and Sharpen your Wahl Hair Clippers, How to Clean and Sharpen your Wahl Hair Clippers: шаг 1, изображение 1 из 1
    • Take your Philips head screwdriver and loosen the set screws by turning them left. This will allow you to separate the blades from your clipper.
  2. How to Clean and Sharpen your Wahl Hair Clippers: шаг 2, изображение 1 из 1
    • Take a fine hair brush and sweep it across the clipper base. This will remove any hair debris.
  3. How to Clean and Sharpen your Wahl Hair Clippers: шаг 3, изображение 1 из 1
    • Fully immerse and soak your blade in 90% isopropyl alcohol to remove any rust that might be present. The blade should soak a minimum of 5 minutes.
  4. How to Clean and Sharpen your Wahl Hair Clippers: шаг 4, изображение 1 из 1
    • Take a clean lint free towel and dry the blade. While drying rub the blade in all directions applying light pressure and this will remove residue and polish the blade.
  5. How to Clean and Sharpen your Wahl Hair Clippers: шаг 5, изображение 1 из 1
    • Run your blade left and right in a horizontal direction across a Whetstone honing stone. First on the coarse side to sharpen the blade then on the finishing side to smooth out the blade.
  6. How to Clean and Sharpen your Wahl Hair Clippers: шаг 6, изображение 1 из 1
    • Rinse the honing stone under water and rub the stone back and forth the same direction you used to sharpen your blade. This will clean your stone and remove any debris.
  7. How to Clean and Sharpen your Wahl Hair Clippers: шаг 7, изображение 1 из 1
    • Place your blades back into position and insert your set screws into the proper holes. Take your Philips screwdriver and turn the screws to the right until you feel them completely tighten. Be careful to line up your blades correctly.
  8. How to Clean and Sharpen your Wahl Hair Clippers: шаг 8, изображение 1 из 1
    • Apply oil to the base of your blades before first use. Blades should be oiled after every 3 or 4 uses.
  9. How to Clean and Sharpen your Wahl Hair Clippers: шаг 9, изображение 1 из 1
    • Your clippers are ready for use. Plug them in to let them run for a few moments before your first use.
Заключение
17 участников успешно повторили данное руководство.
Joseph Makar
Участник с: 02/07/19
699 Репутация
1 руководство автора
Команда
Pasco Hernando, Team S6-G84, Prince Spring 2019 Участник Pasco Hernando, Team S6-G84, Prince Spring 2019
PHSC-PRINCE-S19S6G84
1 член
Автор 5 руководств
8 Комментариев
What kind of oil? wd40 ?
zoobee22 - Ответить
No. WD40 is not a lube and won't last. WD = Water Displacer.
Use mineral oil from your drug store.
Joe -
Much more easily said than done. I am extremely mechanically orientated and have tried three times to sharpen them. They are almost useless (Wahl animal Pro Series) after only two cuts.
Barry Jameson - Ответить
Barry, read my comment to the step 5 - you’ll find how to do it correct.
vladintool -
My shaver after popping the head off to clean stop cutting.what steps can I take to fix this problem?
mdearl54@yahoo.com - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24 час(ов): 62
За последние 7 дней: 463
За последние 30 дней: 2,158
За всё время: 115,917
