Введение
Have you ever noticed all of the build up on your hairbrush? The loose hair and hair products that linger in between the bristles? Well this guide is going to walk you through the technique of how to thoroughly clean and sterilize your hairbrush and make it as good as new.
Выберете то, что вам нужно
Remove the built-up hair from the brush by inserting the comb into one side of the bristles and pulling up.
Dampen the bristles of the brush with warm water
Add a few drops of soap to the bristles
Work the soap into the brush using your fingers to massage the bristles
Thoroughly rinse the brush in warm running water
Set the brush aside and fill the large bowl with hot water
Add ½ cup of white vinegar to the bowl of water
Place the brush into the large bowl with the bristles facing down and let soak for 30 minutes
Remove the brush from the bowl and shake it to remove any excess water
Place the brush on the towel bristles down and allow the brush to air dry
This process should be repeated once a month in order to keep the brush in good condition and keep any dirt and grime build up from being transferred onto your hair .
