How to Clean the Keurig K75 Platinum Brewing System Needle
Выберете то, что вам нужно
  1. How to Clean the Keurig K75 Platinum Brewing System Needle, How to Clean the Keurig K75 Platinum Brewing System Needle: шаг 1, изображение 1 из 1
    • Before needle repair, make sure the brewer is disconnected from any power outlet.
    • Lift the handle to open the top of the brewer.
    • There are two sharp needles that puncture the K-Cup pack. One is above the K-Cup holder and the other is in the bottom of the holder. Be careful when cleaning the top needle.
  2. How to Clean the Keurig K75 Platinum Brewing System Needle: шаг 2, изображение 1 из 1
    • Bend a paperclip to create a vertical metal piece. This is used to clean the top needle.
  3. How to Clean the Keurig K75 Platinum Brewing System Needle: шаг 3, изображение 1 из 1
    • Insert a paper clip into the exit needle to loosen the debris and push it out.
    • Repeat this action until the debris is cleared from the top needle.
    • All external pieces of the brewer are dishwasher safe.
Заключение
2 участников успешно повторили данное руководство.
Alexander Vo
Участник с: 01/11/13
94 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 20-2, Maness Winter 2013 Участник Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 членов
Автор 6 руководств
9 Комментариев
must be something else on mine. i have cleaned out with paper clip 3 times and still no water comes out.
jjthdj - Ответить
try descaling it
marymckercher -
Worked great for mine just now. I picked up a used B20 Platinum at a Garage Sale yesterday for only $10 super easy to clean needle & now it works great!! Thanks OP!!
ronald944 - Ответить
My husband keeps wanting to buy me something new every time the old one doesn't work, well I am old fashioned and will do anything I can to save money. Thank goodness this worked than you so much.
Wendy Clark - Ответить
How about the needle at the bottom of the holder?
tahoejb - Ответить
Clean that too. It can’t hurt.
LARRY RODAMMER - Ответить
I have used filter water ALL WAYS, in my model B 70 I made a cup this AM. I did not need it on any more so shut it down. Or turn off the power switch. Now that not ready light keep blinking. I done every suggestion on, line. Any help. ????????
jrschex - Ответить
where can i get a new silicone gasket
Bill Blogna - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 14
За последние 30 дней: 35
За всё время: 21,912
