How to Clear Voron2.4 Hotend/Nozzle Jams
  1. How to Clear Voron2.4 Hotend/Nozzle Jams, How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 1, изображение 1 из 2 How to Clear Voron2.4 Hotend/Nozzle Jams, How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 1, изображение 2 из 2
    • Load the last filament used before the jam into the printer at normal printing temperature.
    • Below are the temperature ranges for the three most common filament types:
    • PLA: 180-210C
    • PETG: 230-250C
    • ABS: 240-255C
  2. How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 2, изображение 1 из 1
    • Extrude 5-10 mm at printing temp of plastic and then set hotend temp to 0/room temp.
    • Caution: Do not touch the hotend.
    • Wait for hot end temp to drop to room temp.
  3. How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 3, изображение 1 из 2 How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 3, изображение 2 из 2
    • Remove all tension on extruder arm (the part that clamps to the filament to feed into printer).
  4. How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 4, изображение 1 из 3 How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 4, изображение 2 из 3 How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 4, изображение 3 из 3
    • Pull te filament out of the hotend.
    • This may require some force.
    • This is commonly referred to as a “cold pull” and the goal is to remove debris that may be stuck in the nozzle.
    • Repeat the previous steps one to two times.
  5. How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 5, изображение 1 из 2 How to Clear Voron2.4 Hotend/Nozzle Jams: шаг 5, изображение 2 из 2
    • Retension the extruder arm and set the hotend to the printing temp of material.
    • Extrude the material and note the behavior of the plastic as it exits the hotend.
    • Material should flow relatively straight down. Sharp curling as it exits the hotend may indicate that the jam has not been cleared.
Заключение
Alex
Участник с: 01/21/25
121 Репутация
1 руководство автора
Команда
UC Davis, Team 1-2, Morris Winter 2025 Участник UC Davis, Team 1-2, Morris Winter 2025
UCD-MORRIS-W25S1G2
3 членов
Автор 1 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 176
