Введение
It's very easy to clean out a blocked pipe if something is stuck in it. Depending on how your sink is you may not even need tools. This guide will show you how you can easily take care of this issue and unclog, or retrieve what is blocking your pipes.
When you first go to clear your sink, you should check how the pipes are connected.
Gently remove the pipe and find somewhere to dump out the contents that caused it to be clogged.
Clear out the gunk, obstructions, and any other objects in the pipe so that your sink drains properly.
Your sink should now be free of obstructions or clogs in the pipes.
4 участников успешно повторили данное руководство.
Один комментарий
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
