Введение
In this Guide, we will create a service using Automator to change the System Appearance from Light to Dark with a single keyboard shortcut.
Open up Spotlight.
Click the Magnifying Glass in the menu bar.
Use Keyboard Shortcut: Cmd + Space
Choose Quick Action in the window that appears.
Hit Enter or Click Choose
In Workflow receives, Choose Automatic
Beside in, Choose any application
In Image and Color, these will not change the shortcut at all, but you can adjust them to the way you like.
To create the action, choose Library in the Top-Left corner of the window.
Click the Search bar and start typing Change System Appearance
You will see three different commands: Light, Dark, Toggle Light/Dark
Choose Toggle Light/Dark so you won't have to create two shortcuts.
Time to test this action!
Click the Run command in the corner of the window.
If everything is successful, the system should be dark.
Click Run once more to make the system Light
Make sure everything was successful by checking the text at the bottom of the window.
Choose File => Save or Cmd + S to save your Service. Name it whatever you wish.
Click the current Application in the menu bar, and choose Services. There, you will see your new service.
Now we will add a keyboard shortcut to quickly change the system appearance.
Search for System Preferences in Spotlight.
Scroll to the very bottom, you will see a section named General. You will see your Service in this section.
You can now change your system appearance by pressing your shortcut.
