Введение
In this guide, I will demonstrate how to descale a Breville - Barista Pro Espresso Machine BES878-RVC.
After some uses, minerals such as limescale clog the tubes of the espresso machine, damaging it and affecting the coffee's taste. Descaling is the process of removing these built-up minerals.
Keeping up with regular descaling will extend the life of your espresso machine and produce better-tasting drinks!
Выберете то, что вам нужно
Press the power button to power on the espresso machine.
Pour a packet of descaler (or a descaler tablet) into the water tank.
Fill the water tank with fresh water to the descale line located on the side of the water tank.
Press the menu button.
Turn the knob labelled “Filter Size” counterclockwise until the “descale” label is blinking on the display.
Wait for the display to show “d2.”
Rotate the right dial to the hot water icon to descale the hot water dispenser.
Wait for the display to show “d1.”
Rotate the right dial to the steam icon to descale the steam wand.
Wait for the display to show “r.”
Rotate the right dial back to the neutral position.
Pull out and empty the water tank.
Fill the water tank with fresh water to the max line.
Reinsert the water tank.
Press the one cup button to initiate the rinse cycle.
Wait for the display to show “r2”.
Rotate the right dial to the hot water icon to rinse the hot water dispenser.
Wait for the display to show “r1.”
Rotate the right dial to the steam icon to rinse the steam wand.
Once the rinse is complete, the grind amount option will appear on the display.
Pull out the water tank.
Reinsert the water filter.
Refill the water tank with fresh water.
