Введение
If your Mr. Coffee Espresso Machine and Steaming Wand is not producing water out of the group head (where the coffee should come out of) or producing steam out of the steam wand, your espresso maker is probably clogged by mineral build up. A simple descaling process will clear this buildup and restore your machine to prime condition. Even if your machine is not clogged, periodic descaling is recommended to keep your machine at its best and reduce the chance for additional damage caused by clogging.
This guide will walk you through how to make your own descaling solution, descale the espresso machine, declog the steaming wand, and clean out the solution to return your machine to working order. This guide does not require any special skills or parts.
Caution: Never open the water reservoir cap while the machine is pressurized. This can cause the boiling water to erupt out and cause burns. Do not brew out entire volume of descaling solution because the pressure on the machine will be too high. Always allow machine to depressurize overnight before removing the water reservoir cap.
Выберете то, что вам нужно
In a measuring cup, add 1 cup of white vinegar.
Add 2 cups of water.
Turn off the machine.
Twist off the water reservoir cap.
Fill the water reservoir to the top with the descaling solution.
Twist the water reservoir cap back on.
Turn the knob to the brew setting.
Turn the knob to off as soon as the solution comes out.
Fill a cup with the descaling solution.
Remove the steaming wand cover.
Place the cup where the steaming wand is emerged in the descaling solution.
Soak the steaming wand for 1-2 hours.
Remove the cup from under the steaming wand.
Insert an interdental brush or toothpick into the steaming wand.
Move the interdental brush or toothpick around to remove any mineral build up.
Place an empty cup or mug under the steaming wand.
Turn the knob to the steam setting.
Pour out the remaining descaling solution.
Rinse the reservoir twice by filling it with water and pouring it out.
Fill the reservoir with water.
Brew and steam all the water out of the reservoir.
Repeat this process 4 times.
Now that you have descaled your Mr. Coffee Espresso Machine and Steaming Wand, you are ready to start being your favorite barista again. This instruction guide should have taught and helped you descaled your machine successfully. Thank you for reading our instructions, if you have any further questions about your machine visit the Mr. Coffee Website.
