Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The Auto Boot feature powers on your laptop as soon as you open the lid, so it must be disabled before undertaking certain repairs. Auto Boot can be found on 2016 (and newer) MacBook Pros and 2017 (and newer) 12" Retina MacBooks.
This guide will walk you through the process of disabling Auto Boot, and then re-enabling it when your repair is complete.
  1. Power on your Mac and launch Terminal. To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon. To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
    • Power on your Mac and launch Terminal.
    • To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
  2. Copy and paste the following command (or type it exactly) into Terminal: sudo nvram AutoBoot=%00
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return].
    • Your [return] key may also be labeled ⏎ or [enter].
    • If you are prompted for an administrative password, type the password and press [return].
    • Your password will not be displayed in Terminal.
  3. You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
    • You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
    • Remember, you must still disconnect the battery before servicing internal components.
    One slight problem I found with the Mid 2018 MacBook Pro 13-inch: It still powers on if you accidentally touch the touchpad or inadvertently press a key. Is there a way to disable this behaviour temporarily whilst carrying out repairs?
    On top of that, I couldn’t find a comprehensive 2018 teardown guide, so wasn’t even sure which one was the battery connector. I disconnected what I thought was the battery, but viewing some other videos, it appears I didn’t have the battery disconnected whilst replacing the screen! Out of sheer luck, nothing got fried and the replacement screen works fine.
    Cool_Breeze - Ответить
  4. When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature. Power on your Mac and launch Terminal. Copy and paste the following command (or type it exactly) into Terminal:
    • When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
    • sudo nvram AutoBoot=%03
    • Press [return].
    • Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
Заключение
Congrats! You're done.
11 участников успешно повторили данное руководство.
Jeff Suovanen
Участник с: 06.08.2013
317 639 Репутация
Автор 255 руководств
Команда
iFixit Участник iFixit
Community
129 членов
Автор 12 952 руководств
Комментариев: 4
hello may i ask, how do u make it Jeff$? mine’s scarlet$ and i want to change it but idk how
srhshahdzan - Ответить
I can’t type anything into the terminal…what am I doing wrong?
Linda Sussman - Ответить
HELP
it doesn’t work on MacBook Air><
my sister’s pro did work, thanks!! but mine can’t do so. what should I do???
Ching-Hsien Chou - Ответить
This code change DOES NOT work.
MFMauceri - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 54
За последние 7 дней: 342
За последние 30 дней: 1,223
За всё время: 16,358
