Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The Auto Boot feature powers on your laptop as soon as you open the lid, so it should be disabled before undertaking certain repairs. Auto Boot can be found on 2016 (and newer) MacBook Pros and 2017 (and newer) 12" Retina MacBooks.
This guide will walk you through the process of disabling Auto Boot, and then re-enabling it when your repair is complete.
Note: This procedure only works for Intel-based MacBooks. At this time, we don’t know any procedure for disabling Auto Boot on Apple’s newer ARM-based M1 MacBook Pro or MacBook Air, released in late 2020.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return].
If you are prompted for an administrative password, type the password and press [return].
Power on your Mac and launch Terminal.
sudo nvram AutoBoot=%03
Press [return].
Congrats! You're done.
53 участников успешно повторили данное руководство.
16 Комментариев
hello may i ask, how do u make it Jeff$? mine’s scarlet$ and i want to change it but idk how
I can’t type anything into the terminal…what am I doing wrong?
HELP
it doesn’t work on MacBook Air><
my sister’s pro did work, thanks!! but mine can’t do so. what should I do???
This was a great help to replace my MacBook Pro battery. Great step by step explanations. I received kit and followed the directions.
