How to Disassemble an OXO Container Lid for Cleaning
Выберете то, что вам нужно
  1. How to Disassemble an OXO Container Lid for Cleaning, How to Disassemble an OXO Container Lid for Cleaning: шаг 1, изображение 1 из 2 How to Disassemble an OXO Container Lid for Cleaning, How to Disassemble an OXO Container Lid for Cleaning: шаг 1, изображение 2 из 2
    • Twist the bottom piece off by following the directions displayed on the lid.
    • Once inside, remove the outer layer seal from the lid by pulling it straight up.
  2. How to Disassemble an OXO Container Lid for Cleaning: шаг 2, изображение 1 из 3 How to Disassemble an OXO Container Lid for Cleaning: шаг 2, изображение 2 из 3 How to Disassemble an OXO Container Lid for Cleaning: шаг 2, изображение 3 из 3
    • Flip the lid so the button faces up. Then remove the button from the base of the lid.
    • This requires more added force.
    • Separate the interior prongs.
  3. How to Disassemble an OXO Container Lid for Cleaning: шаг 3, изображение 1 из 2 How to Disassemble an OXO Container Lid for Cleaning: шаг 3, изображение 2 из 2
    • After separating the prongs, the spring and the circular spring cap will separate from the square frame with little force.
    • With some force, remove the two prongs from the base of the lid by snapping them out of the bracket. Be careful not to break the bracket's small prongs.
    • The disassembled parts can now be cleaned with warm, soapy water.
  4. How to Disassemble an OXO Container Lid for Cleaning: шаг 4, изображение 1 из 2 How to Disassemble an OXO Container Lid for Cleaning: шаг 4, изображение 2 из 2
    • To reassemble the lid, start by connecting the outer layer piece with the base piece. Grooves in the parts will only allow them to be connected in the correct way.
    • Place the spring in the center of the lid within the circular outline.
  5. How to Disassemble an OXO Container Lid for Cleaning: шаг 5, изображение 1 из 1
    • Take the small interior circle and place it on top of the spring.
    • Use force to push this piece down. Make sure the slots align.
    • This piece will not stay in place on its own. Flip the lid over and keep it on a flat surface to prevent the spring from releasing.
  6. How to Disassemble an OXO Container Lid for Cleaning: шаг 6, изображение 1 из 2 How to Disassemble an OXO Container Lid for Cleaning: шаг 6, изображение 2 из 2
    • Reattach the two prongs to the lid.
    • Intertwine the two prongs together.
    • The spring should now be firmly held in place.
  7. How to Disassemble an OXO Container Lid for Cleaning: шаг 7, изображение 1 из 2 How to Disassemble an OXO Container Lid for Cleaning: шаг 7, изображение 2 из 2
    • Twist the bottom piece back on the lid.
    • Reattach the button to the center of the lid.
Финишная прямая
2 человек успешно провели ремонт по этому руководству.
Lorna Lauro
Участник с: 04/20/22
187 Репутация
1 руководство автора
Команда
CSU Los Angeles, Team 7-77, Harris Spring 2022 Участник CSU Los Angeles, Team 7-77, Harris Spring 2022
CSULA-HARRIS-S22S7G77
1 член
Автор 1 руководств
1 Комментарий к руководству
Excellent guide, a set I got came with the metal pins of the prongs unseated from their holes, causing the lid to operate incorrectly. I was able to re-seat them and get the lid working with the help of this.
Stefan Rust - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 12
За последние 7 дней: 51
За последние 30 дней: 226
За всё время: 16,964
