Введение
It's always a good idea to disconnect the battery before working on your vehicle's ignition system or other electrical components. (If you need to fully remove or replace the battery, follow this guide instead.)
This guide uses a Toyota Corolla to demonstrate the procedure, which is similar for most motor vehicles.
Note: Disconnecting your battery may erase certain stored settings, such as radio/navigation presets and power window memory. Consult your owner's manual for details.
Выберете то, что вам нужно
Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
If you're not sure, simply continue reading.
Pull the hood release lever. It's usually located inside the car, near the steering wheel.
Raise the hood by simultaneously lifting and pressing up on the hood latch release (usually located beneath the front edge of the hood, near the center or center-right).
If not, use one hand to hold the hood open temporarily while securing the hood with the prop rod:
Lift one end of the prop rod up or out to release it from the front area of the engine bay.
Swing the end of the prop rod up and slide it into the cutout on the underside of the hood.
Locate the battery. It's normally rectangular and roughly 8-14" across.
On some models, the battery may be located in the trunk—usually under or behind the trunk lining. Look around or consult your owner's manual.
Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the negative battery terminal.
If the nut or bolt spins without loosening, it may be necessary to counter-hold the opposite side with a second wrench or socket.
4 участников успешно повторили данное руководство.
