Введение
This guide will teach you how to downsize the waistband of a pair of jeans without sewing.
Выберете то, что вам нужно
While wearing the jeans, pinch the excess fabric at the center of the backside of the waistband.
Keeping the excess fabric pinched, place two highlighter marks at the point where you with the waist to touch.
Once done, remove the jeans and lay them flat with the front side up.
Locate the points on the seam directly below the two highlighter marks.
Using the seam ripper or a pair of scissors, break the two seams to loosen the lining along the fabric.
Starting from where one of the seams is broken, cut up the waistband, stopping just before reaching the top.
Repeat this process for the other broken seam point.
Measure and cut out a strip of elastic that is slightly smaller than the distance between the two cuts on the waistband.
Attach a safety pin onto each end of the elastic strip.
Using the safety pin, attach one end of the elastic strip to the waistband directly outside of one of the cuts.
Slip the free end of the elastic strip into the nearest cut.
Push the elastic strip along the waistband through the other cut using the safety pin as an aid.
Similar to the process in step 6, attach the elastic strip just outside of the cut using the remaining safety pin.
To change the size again you can use a looser or tighter elastic band. If a more permanent fix is required, sewing in place of the safety pins is a possible, but more challenging fix. Please note that because of where the cuts are made you will not be able to alter the size drastically the second time you alter them.
9 участников успешно повторили данное руководство.
