Введение
Newer Mac Laptops have USB-C or MagSafe 3 instead of MagSafe or MagSafe 2 for charging. When you insert a USB-C or MagSafe 3 power adapter into a Mac laptop with those connectors, you'll hear a chime, indicating that the Mac laptop's battery is charging. Older Mac laptops without USB-C or MagSafe 3 don't have this function. You can enable this charging chime with a simple terminal command.
PS: The charging chime on newer Mac laptops is the same chime that's used on iPhones, iPads, and iPod touches to indicate charging on those devices.
Disconnect your MagSafe/MagSafe 2 power adapter.
Go to the spotlight search and search for Terminal. Open Terminal by double clicking it in the results area.
Paste the following command into the Terminal window and press enter
defaults write com.apple.PowerChime ChimeOnAllHardware -bool true; open /System/Library/CoreServices/PowerChime.app &
Done! Reconnect your MagSafe/MagSafe 2 power adapter and you should hear the charging chime
To disable the charging chime, simply change -bool true; in the command above to -bool false;
17 участников успешно повторили данное руководство.
3 Комментариев
This is cool, thank you!
how to DISABLE THIS SOUND ? :)
Hey there! You are able to turn off the chime by simply changing the command:
Turn on:
Turn off:
defaults write com.apple.PowerChime ChimeOnAllHardware -bool false; open /System/Library/CoreServices/PowerChime.app &
Difference is that the ‘on’ command states true and the off command states ‘false’
Try to attempt this, it may not work depending on your mac
EB R -
excellent. it worked exactly how it said after i raised the volume without having to restart
Ajay Koonuru - Ответить
